Is there a charge controller/balancer/manager built-in here ?
Externet
Joined Nov 29, 2005
2,638
Hi.
Planning to buy some of these automotive sized and looks batteries. Do you know if can receive charge just by applying regulated 14.4V ?
Hi.
Yes, every battery like that has a BMS to control the charging to protect the cells.
When the battery is full, it will internally disconnect from the charger and when fully discharged it will disconnect from the load.
https://www.weizeus.com/pages/faqs
Yes, WEIZE LiFePO4 batteries are equipped with a sophisticated Battery Management System (BMS), which includes a low-temperature sensor. This sensor is a crucial component of the BMS and serves several essential functions.
bigjoncoop
Joined Feb 1, 2019
204
@Externet
That battery does have all of that besides a built-in charger.
Inside the battery is a BMS which is a battery management system.
It will monitor the voltage of each cell to ensure the voltage is not go too high or too low. So while charging the battery, if the voltage of any of the cells goes above 3.65v it will disconnect the battery from the charger automatically. Also while using / discharging the battery, if the voltage goes below 2.5v or so, it will also disconnect the battery automatically. It will not allow the battery to function until a charger is applied and brings the voltage back up.
YOU STILL MUST USE A BATTERY CHARGER RATED FOR A LifePO4 4s 14.8v BATTERY!!! IT'S POSSIBLE TO USE 12V SLA / LEAD ACID / CAR BATTERY CHARGER IF YOU NEED TO...
