Is that okay to bias a transistor like this?
asdf arfw
Joined Sep 9, 2017
43
http://tinyurl.com/ybvwgmnw
Should I put some resistors between +5v and Vc? I just want to amplify currents to let LED works because I don't know the value of resistor between +5v and Vb if it's too high the LED won't work at all so I put the transistor to make sure it still work in that case.
35,268
Depends on what you are trying to do.
If you want the LED to just stay on, use a resistor and LED alone. Omit the transistor as Dick says.
asdf arfw
Joined Sep 9, 2017
43
http://tinyurl.com/y7pkf7gd
Okay, I should give you more information about my school project.
I actually designed my own measurement water level and the problem is the water isn't a good conductor at all and its conductivity isn't constant depends on where I took the water from. So when I put it in the water my LED won't work at all. I decide to use transistors to amplify currents to make sure it still works when the conductivity of water is too low. I want to know is that okay to bias a transistor like I posted on the top because
the current from Emitter is the highest and I want to use it for my LED but I never saw someone bias a transistor like that before.
