Replacement Treadmill Control Board 220v But Treadmill Says 110v...is it okay to replace with that control board?
MaxHeadRoom
Joined Jul 18, 2013
30,887
Not if the board was intended to be used in a 220v treadmill, it is safe to assume the board would be configured to run at that voltage.
Alec_t
Joined Sep 17, 2013
15,171
Can I use a control board that says 220v for my treadmill that says 110v?
It depends on the board design. You have to consider power (Volts x Amps) as well as voltage. A board designed for 220V might be able to handle only half the current than one designed for 110V.
mannytreadmill
Joined Jun 6, 2021
8
Thanks I might have to take a chance/try. I am waiting to hear back from the sellers of this model
