Is my math corecct? Please help.
1213brett
Joined Feb 1, 2015
13
I'm trying to find out if my mosfet needs a heat sink. my load draw 1.20 A and im triggering the mosfet with ardino pin 7 5V
P= current squared * RDS
1.20 A * .16 Ohms squared = .2302
TJmax - Tambient / ROJA
150 - 25 / 62 = 2.02
2.02 is larger then .2302 so I need a heat sink
ScottWang
Joined Aug 23, 2012
7,505
How is your load V/I, do you have a circuit?
You can choosing some other mosfets has lower Rds then it could reducing the power consumption.
33,115
Note that
150 - 25 / 62 = 149.60
Remember order of operations!
If you mean (150 - 25) / 62, then say so.
Also, use your units and your answer becomes much more informative:
Pmax = (TJmax - Tambient)/ROJA = (150 °C - 25 °C)/(62 °C/W) = 2.02 W
Pactual = I²·Rds = (1.2 A)²·(0.16 Ω) = 0.23 W
Since Pactual < Pmax, no heat sink needed.
uwed
Joined Mar 16, 2015
64
Rds=0.16 ohm is usually normalized (room temperature). If you operate at Tj=150°C we would have Rds=2.2*0.16=0.35ohm (see Fig.4 in the datasheet).
