I'm working on a project that requires the use of a power transistor. The transistor is a BJT, and I'm running a heavy amount of current through it (about 20 amps). I bought a huge heat sink for the transistor, and have noticed that, when in operation, the transistor gets way hotter than the heat sink. If I place my finger on the transistor, it's too hot for me to keep my finger on it. At the same time, if I put my finger on the heat sink, right next to the transistor, the heat sink is cold.
My suspicion was that I wasn't using a good thermal paste. I had bought some thermal paste, from Best Buy, and it's advertised to have a thermal conductivity of 3.8 w/(m*k). I figured that, if I got something with a much higher thermal conductivity, I'd notice a big difference.
So, I looked up different thermal pads, on Digikey, and noticed that some of them can go as high as 1,800 w/(k*m). The one I saw, was made of graphite. According to what I've read about graphite, it tends to have a thermal conductivity that, often, is, at least, in the hundreds.
I have a thin sheet of graphene, and decided to use that. Because it's not a hard material, I figured it may squish fairly well -- like a thermal pad. To my disappointment, the temperature difference didn't feel any different than with the stuff that's 3.8 w/(m*k). On top of that, I've noticed that Dow 340; a thermal paste that seems to be popular for power amplifiers, only has a thermal conductivity of 0.67 w/(m*k).
Am I missing something? Can anyone explain whether or not the huge temperature difference, between transistor and heat sink, is normal? Also, shouldn't a material with a much higher thermal conductivity, work a lot better?
Thanks for your time and attention. Any insight, that anyone is willing to provide, will be greatly appreciated.
