Is IC power required?
hihihi8
Joined Oct 4, 2017
10
Hi peeps, I'm trying to build an amp based off a schematic found online, which uses TL072, BA4560, and a TDA2030A. However, only the TDA2030 IC has power input drawn. On the TL072 and BA4560 chips, simply no power leads are drawn above/below the transistor triangles. Do these chips even work without VCC and VEE? thanks
bertus
Joined Apr 5, 2008
22,925
All chips do need power.
Without the power they will not work.
Often the powerlines are not shown in the schematics.
34,812
No such luck. There's no free lunch here.
Sometimes folks leave out the power connections in their drawings. These are taken for granted. They also leave out the power supply decoupling capacitors. These are essential in your real circuit.
18,104
On the TL072 and BA4560 chips, simply no power leads are drawn ...
Those are both op-amps and require power. I think it's a fair assumption that they are intended to get the same power as the IC that is connected. If a different power was necessary, it would make sense to include that information on the schematic.
ian field
Joined Oct 27, 2012
6,536
The emergence of energy harvesting devices broadens the amount of interpretations that question is open to.
The best answer for the TS's question is that most op-amp and logic drawings leave out the power line indications to avoid a cluttered schematic.
34,812
Nope. Never.
CMOS gates will power up from voltages applied to the inputs of gates. Current from input signals conduct through the input protection diodes and can supply the Vdd power plane since the current requirements are in microamps.
dl324
Joined Mar 30, 2015
18,328
I think it's pretty clear in my post that I was replying to the OP's notion of "these"...
Powering up CMOS through their outputs or overdriving their inputs are issues that are common knowledge and thoroughly documented.
34,812
I'm just making sure that newbies are familiar with these nuances.
