Hi peeps, I'm trying to build an amp based off a schematic found online, which uses TL072, BA4560, and a TDA2030A. However, only the TDA2030 IC has power input drawn. On the TL072 and BA4560 chips, simply no power leads are drawn above/below the transistor triangles. Do these chips even work without VCC and VEE? thanks
