Is have larger wire size can make circuit braker trip more fast ?
meowsoft
Joined Feb 27, 2021
666
Example : use 35a wire for 16a load
ronsimpson
Joined Oct 7, 2019
4,814
Under a short condition, a larger wire will have less resistance and conduct more current, so probably the breaker will trip faster.
Another way to think about it. (not a short condition)
1)10A breaker. 10.1A load, 16A wire, voltage loss because of the wire is 10 volts, the breaker pops in 5 minutes.
2)10A breaker, 35A wire so the loss in the wire will be less so lets say there is 5 volts loss in the wire, so the voltage on the load is higher by 5 volts than in example (1), so the load is 10.6A. Now the breaker will pop in 2 minutes.
3) 10000A wire, wire loss is almost nothing, voltage on the load is higher, current is 11.1A and the breaker pops in 30 seconds.
GetDeviceInfo
Joined Jun 7, 2009
2,284
Generally, your wire and O/C are sized together. Increasing your wire size will not alter the characteristics of the breaker. It may however influence other components of the circuit. Some code calculations are based on wire size, and changing it in one section may dictate that it must be changed in others, as well as ratings for devices. Feeders are an example. There are many types of breakers with varying characteristics, depending on the load requirements and required protection schemes.
Regardless, you should be able to view the data from your specific breaker and make a logical deduction about what you ask.
meowsoft
Joined Feb 27, 2021
666
What's if we use NH fuse ? It is more instantly cut the circuit ?
meowsoft
Joined Feb 27, 2021
666
I think circuit breaker specifically MCB is not really safe...
28,310
A proper circuit breaker has a defined overload versus time characteristic and so the wire size, as long as it is at least adequate, will not have an effect worth considering. So using 20 amp wire on a circuit with a 15 amp breaker provides no benefit, except if there is a need to change to a 20 amp breaker in the future.
Of course, this is assuming that copper wire is used.
With aluminum wire there may be some benefit in using 30 amp wire for a 10 amp circuit, if the proper connection arrangements are used. That mmay tend to reduce the wire heating somewhat.
Papabravo
Joined Feb 24, 2006
22,111
Only if the breaker was intelligent enough to know what size wire you had. It only uses what's inside to make it's determination
meowsoft
Joined Feb 27, 2021
666
It is copper not aluminium, aluminium is so bad, also difficult to find in my local area, minimum size is 10mm², and it's very large for office use, imagine you have 3x10mm² aluminium XLPE insulated wire under the table, also aluminium outlets it's hard to find
meowsoft
Joined Feb 27, 2021
666
Yes... it's good idea to install CT sensor with micro-controller and detect when something is shorted then trip a contactor coil / mccb with shunt trip ?
meowsoft
Joined Feb 27, 2021
666
No... I just wan to make installation with can properly used even degraded by age, so... I calculate maximum use of wire is about ~30%, if 10 years later capacity is degraded 15% that wire still only use ~38% capacity, it's very safe
28,310
My point in mentioning aluminum wire is that it has a number of different additional challenges. I do not ever recommend aluminum wire, nor components, for interior power wiring.
meowsoft
Joined Feb 27, 2021
666
Ok... it is good idea for use aluminum wire for outdoor purpose ?, wind turbine ? generator set ?
28,310
OUr utility companies use aluminum wire for distribution. It reaches as far as my house, where it transitions to the copper wire that I provided. I do not choose to use aluminum wire at all, anywhere. It is much more effort to make a good connection with it and so I do not recommend it anywhere.
IN another part of the world aluminum wire is used in new construction because the theft of copper wire is such a problem. I do not know how they avoid the well known problems that may result. Someplace here is the thread about that issue.
