Is earth a conductor or insulator
Status
Not open for further replies.
mik3
Joined Feb 4, 2008
4,843
I wanted to know whether is a conductor or insulator,and in what conditions
Earth can conduct electricity but not as good a wires. Its resistance depends on the kind of the ground , how far is one point from the other where you measure the resistance, the moisture, and other factors. Search in google to find more specific answers.
Wendy
Joined Mar 24, 2008
23,811
I have to agree with the conductor assessment. Earth is used as a reference for most voltages, even when it isn't acually used. It is where the term ground came from.
scubasteve_911
Joined Dec 27, 2007
1,203
I disagree with the conductor assessment :p
Earth, since it is an extremely large connected mass, will not build up a charge very easily. Earth has an electric potential of zero, since there is no charge. This is why circuits are referenced to earth. In order for there to be a conductor, you need a many free ions, which it does not have.
Steve
beenthere
Joined Apr 20, 2004
15,819
The earth does have many free ions (possibly you meant to say electrons). Its ability to conduct makes it possible to use it as a measurement reference. In the first years of telegraphy, the earth was used as the conductor that completed the energizing circuit.
Your assessment of the earth's potential being zero is a measure of conductivity. If it weren't conductive, potential would build up in areas and cause lightening-like discharges.
Wendy
Joined Mar 24, 2008
23,811
There may be spots where conductivity isn't as good as others, but in whole the earth is a big chunk of iron, with a salty water and slime coating. We do get lightning, but the charge has to conduct for it to occur. It is significant that most lightning is generated in the atmosphere.
Don't think it's conductive? Go stand outside in your bare feet and hold a hot wire. But before you do make funeral arrangements.
If the net charge is zero where do you think the magnetic field comes from? We have a significant one.
studiot
Joined Nov 9, 2007
4,998
big chunk of iron
Well yes there is some iron but also even more aluminium. Nevertheless it depends upon the state of the substance.
Metallic aluminium is one of the best conductors. Aluminium oxide on the other hand is one of the best insulators.
Most iron and aluminium occurs as oxide.
The original poster also asked about conditions. The truth is of course much more complex.
Conductors are normally those substances which have close or even overlapping occupied and empty valence bands of electrons.
Insulators have widely separated bands.
Textbooks consider pure substances when considering this question. And relatively small samples of these substances. So the valence bands stretch uninterrupted from one end of the sample to the other.
The Earth, on the other hand, is an extremely non homogenous large mixture. This mixture contains many internal and surface conducting paths which extend a full range of distances from microns to thousands of kilometers.
But you can also draw many paths through and over the surface of the earth which are non conductive.
So yes the Earth is both conductive and non conductive. You can change the conditions by for instance adding water.
A simple example is the cable that wires your house. Is that conductive or non conductive?The copper wire is conductive, the plastic sheath is nonconductive (you hope). If you connect make a connection to the wire at one end and the plastic at the other........
These characteristics are use in geophysical exploration in the form of resistivity surveying using the conduction current and with ground penetrating radar using the displacement current.
Finally the earth - atmosphere system forms a huge capacitor.
The earth's surface forms the lower plate and the so called electrosphere forms the upper plate, charged to about 300,000 volts. The electrosphere extends over the whole globe at about 50 Km up and is formed from conductive ions in the air. It is between this layer and the surface that lightning discharges.
The resultant field can readily be measure by simple instruments and is used in one system of aerial navigation - the Maynard Hill system.
Wendy
Joined Mar 24, 2008
23,811
For the most part you are talking the crust, especially where aluminum and silicon are concerned. The core is primarily iron, molten but pure, which is where the magnetic field is coming from as I understand it. The surface is also pretty wet, by any standard, even the driest part of this planet have some humidity, unless the temperature is way below freezing.
We may be arguing semantics, but finding a dry land area of earth (which is 1/3 the surface of the planet) that isn't conductive is the exception rather than the rule, by a large extent. I'll stick with my original answer.
Again, you can receive a lethal shock from relatively low voltage systems just through the earth and a hot wire. This is pretty much universal.
I've been reading some interesting articles about Tesla's broadcast power systems that suggest this conductivity, along with the capacitance of the atmosphere (the upper atmosphere is conductive while the lower atmosphere is insulative), is the basis of his broadcast power scheme, which is a major misnomer. It wasn't broadcast at all, at least not through the atmosphere. The earth has a resonance frequency also, which Tesla predicted and has been experimentally verified, of around 7 Hz. If anyone is interested I'll look up the links again.
circuitashes
Joined May 13, 2008
37
I've been reading some interesting articles about Tesla's broadcast power systems that suggest this conductivity,....The earth has a resonance frequency also, which Tesla predicted and has been experimentally verified, of around 7 Hz. If anyone is interested I'll look up the links again.
I did some reading on this a few months ago. The earth has indeed been proven by Nikola Tesla to be a conductor. You can check this wiki link under the heading 'Colorado Springs' : http://en.wikipedia.org/wiki/Nikola_tesla
Here are some extracts from that link:
"....Tesla's diary contains explanations of his experiments concerning the ionosphere and the ground's telluric currents via transverse waves and longitudinal waves.[62] At his lab, Tesla proved that the earth was a conductor,...."
"....He transmitted extremely low frequencies through the ground as well as between the earth's surface and the Kennelly-Heaviside layer....."
Wendy
Joined Mar 24, 2008
23,811
I used to work around something called TACAMO ( http://en.wikipedia.org/wiki/TACAMO ) at Collins radio that was an ELF system. I didn't have the military clearance, but techs will talk, at least in generalities. I can't speak for what you were referring to, but the ELF systems we worked on were broadcast over the air waves, with several miles of wire strung behind a large airplane. They had a pexiglas tube around the coils on this transmitter, as it would glow with a nice nimbus and reach out an bite you if you got too close.
beenthere
Joined Apr 20, 2004
15,819
I've heard tales of replacing the filaments in ground based ELF transmitters. You opened the hatch and climbed in with a welder to do the deed. Took a couple of days to pump the thing down to a hard enough vacuum to work again.
Wendy
Joined Mar 24, 2008
23,811
Necroposting is discouraged. I am closing this thread, if someone wants to pick up the conversation a new thread can be started.
Status
