Is any proper way to check LCD 16x2 JHD162A ?
AVINASH_08
Joined Jan 14, 2016
31
Hello All
I am trying to make some stuff on LCD , I have purchase new LCD JND162A and write one simple code and burn it on Atmega32A.
I found this is not working , LCD not showing any thing ,no any box structure only green light turn on. I had check my connection several times.
I had check this on Proteus simulation software, code and LCD works properly.
Connection method I had follow
1) VSS=gnd ,VCC-5v, VEE-5v directly ,LED+ -5v, LED- - gnd directly and data pins respectively .
2)VSS=gnd ,VCC-5v ,VEE- 10k POT ,LED+- 5v through 330OHM ,LED- - gnd directly and data pins respectively.
Is my LCD is damage with this first method of connection ?
Is any proper way to check or test LCD with out connecting to Micro controller ?
Is any way to repair LCD JHD162A ?
philba
Joined Aug 17, 2017
959
Vee (pin 3) is your contrast voltage. you need to use a potentiometer (5K, 10K, 20K will work) as a voltage divider (one end to Vss, other end to Vdd and the wiper to Vee). Adjust until you see blocks and then tweak it for the best display.
AVINASH_08
Joined Jan 14, 2016
31
Vee (pin 3) is your contrast voltage. you need to use a potentiopalso ot meter (5K, 10K, 20K will work) as a voltage divider (one end to Vss, other end to Vdd and the wiper to Vee). Adjust until you see blocks and then tweak it for the best display.
I use 4.7k ohm directely and then after that i check with 10k pot also ..but i wont see any blocks.
So is my LCD is damage ?
philba
Joined Aug 17, 2017
959
It could be but it could also be any number of issues. Have you verified the voltages Vss - Vdd and Vss - Vee with a DMM? What voltage are you seeing?
dendad
Joined Feb 20, 2016
4,642
Try a small diode, 1N914 or 1N4148 for example, anode to VEE and cathode to VSS. In most cases that will work ok in place of a pot. Then the screen should show blocks when it powers up.
But yes, if the VEE is at 5V, it will not work.
AVINASH_08
Joined Jan 14, 2016
31
thank you dendad i will check this today and make you inform.
