IRF540N application as a switch trouble
jim0000
Joined Oct 28, 2020
130
Stop thinking of it as a switch between the positive supply and the load. An N-channel MOSFET is used as a switch between the load and ground. If you need a switch between the positive supply and the load you need a P- channel MOSFET.
The same is true for NPN and PNP bipolar transistors.
Bob
Okay that makes a lot more sense.
Bob
I actually didnt know that. Thank you
Audioguru again
Joined Oct 21, 2019
6,826
The P-channel Mosfet is turned off only when its gate voltage is the same as its source voltage, +20V.
The NPN transistor turns on and turns on the Mosfet when its base voltage is a little more than 0.7V. They both turn off when the base voltage is less than about 0.4V.
Audioguru again
Joined Oct 21, 2019
6,826
The emitter of the transistor is shown properly connected to ground, then a positive voltage on its base turns it on and a low voltage or ground on its base turns it off.
When the transistor turns on then its collector goes to ground which applies the 20V across the 10k and 12k resistors and the resulting 11V across the 12k resistor turns on the P-channel Mosfet which turns on the load.
38,946
If you can put the load between the supply voltage and the MOSFET drain, then you can use an N-MOSFET with the source grounded as a switch.
If the load must be grounded, then you need to use a P-MOSFET with the source to the supply and the drain to the load.
You will then also need an NPN transitor to drive the gate of the P-MOSFET.
jim0000
Joined Oct 28, 2020
130
Thats something I was trying to work through actually. Wow thank you, I was wondering how I could turn it off given the requirements.
