Greetings,
I'm having a issue with a Gate switching power supply using a IR2110. The problem is in the bootstrap circuit that is being used isn't working.
I looked at different configurations but I haven't seen this type of design.
The original problem is with no gate signal the IC voltage on Vb Vs and Ho were reading 50 vdc. So I changed C6 and C3 but I don't think
I used the correct diode. After I changed the parts I still don't get the correct voltages compared to the LTspice files that I have attached.
I have no idea what the original schematic is because there is none.
I would like to change d3 and see if that corrects the problem but I don't know what type number diode to use. I can't identify the part number.
Thanks in advance,
Jeff M.
Thanks in advance,
Jeff M.
