IR2110 HV CONTROL
david342a
Joined Nov 1, 2021
6
What happens if the circuit is run without a load, how can I protect the mosfets, my output current is 2A duty 97% Freq 2HZ
ronsimpson
Joined Oct 7, 2019
4,888
97% on for Q1?
2hz is a long time!
The energy to keep Q1 on is stored in C1, C2. R3 is discharging C1. Make R3 as large as you have. (1meg or more)
I have not done the math but R3 * C1 time constant needs to be 1 second or more. There there is current to run the IC and that is in the data sheet.
I have a circuit like this where I keep Q1 or for hours. I removed D1 and added this power supply. It lives on +12V and makes a isolated 12V to turn on Q1.
Input voltage options are 5V, 12V 15, 24 .....
Output options are 3, 5, 12, 15, 24
1W and 2W
Circuit should be OK with no load.
david342a
Joined Nov 1, 2021
6
97% on for Q1?
2hz is a long time!
1W and 2W
What should my R3 C1 value be for 2 hz? what is the math?
I don't understand if the mosfets will be damaged under no load, what do I need to change?
My frequency is 2 Hz but Q1 on time should be 500 uS How should my HIN and LIN timing be?
