IR sensor to PLC connection
db000
Joined Apr 27, 2022
5
I plan to use an IR transmitter and receiver with 24V supplied by the PLC, I'd then attach the output from the transistor to one of the PLCs digital inputs.
Was wondering whether the circuit included would work okay? If not how can I improve it?
Cheers
MrSalts
Joined Apr 2, 2020
2,767
The voltage at the collector of your transistor will always be at 24v and the emitter will always be at ground. Why is the transistor there?
db000
Joined Apr 27, 2022
5
Would I not require a level shifter? Or would the digital input pin still read it without ?
MrSalts
Joined Apr 2, 2020
2,767
Is the 24v turning on and off to send some digital signal to the PLC, or is it an analog value between 0-24v? Or is there a 4-20mA signal?
Then your output is to a logic level (0-5v or 0.3.3v) and please specify if it is digital or analog.
db000
Joined Apr 27, 2022
5
I'm supplying a constant 24V to the IR LED and photodiode to sense movement. I want to send a digital high input to the PLC when movement is detected.
Sensacell
Joined Jun 19, 2012
3,787
What is missing is a resistor in the collector circuit.
Add a 4.7 k resistor there and take the signal off the collector.
What kind of physical range are you expecting from this sensor?
db000
Joined Apr 27, 2022
5
thanks will do
not expecting anything spectacular as far as range goes, its just for proof of concept at the moment
MaxHeadRoom
Joined Jul 18, 2013
30,810
You could connect the collector of the 2N2222 to the opto isolator in the PLC input terminal.
What do you need the LED indicator for, there is normally a status LED in the PLC input.
Does the PLC sink or source inputs?
MrSalts
Joined Apr 2, 2020
2,767
You'll be lucky to get an 8" (20 cm) range. Ir sensors like a garage door opener safety system pulses at 38k Hz and the receiver has a high gain amplifier that filters out all signals that are not 38kHz.
MrSalts
Joined Apr 2, 2020
2,767
It's not an LED indicator, it is his IR emitter to sense motion (beam interruption) to his photodiode.
