IR Emitter questions
davebee
Joined Oct 22, 2008
540
Connect the device to a voltage with a series resistor to limit the current to a few milliamps. If you have a 5 volt supply, a 2.2k resistor would be a good size.
Measure the voltage across the resistor to find the current (or use a milliammeter directly).
If the device is a detector, then you should see the current vary quite a lot when you shine a light on the device.
If the device is a transmitter, then just point an ordinary digital camera at it and look at the screen.
There's nothing special to do with the camera; all you do is when the camera display is showing what its lens is seeing, you just point the camera at the LED. My Canon digital camera shows IR LEDs glowing with kind of a dull bluish glow. It's not bright, but it's easily seen.
If little no current flows, then the device might be connected in the wrong polarity, so try it with the leads connected the other way.
