Do you mean that the nodes are not connected well ?My guess is that Hin and Lin are not lining up properly.
The IR2110 doesn't provide any significant dead time internally. It's up to the user to provide appropriate Hin and Lin signals.There needs to be a certain amount of "dwell" time with those gate drives to prevent shoot through doesn't there?
I understand that. But gate drivers do need to have the dead time. where the sg3525 doesn't. Or that is my understanding of the sg3525.The IR2110 doesn't provide any significant dead time internally. It's up to the user to provide appropriate Hin and Lin signals.
The SG3525 datasheet says "A wide range of deadtime can be programmed by a single resistor connected between the CT and Discharge pins."But gate drivers do need to have the dead time. where the sg3525 doesn't.
S | can i replace a ir2104 with 2110? | General Electronics Chat | 1 | |
R | IR 2110- simulation | Power Electronics | 24 | |
I | IR 2110 get damaged when connected to trafo | General Electronics Chat | 34 | |
M | Ir 2110 | General Electronics Chat | 4 | |
Y | half bridge using IRF 2110 IC | General Electronics Chat | 2 |
