I have a problem running the example from the socket tcp server on my esp32s3, I use vs-code as a programming environment.
I have ipv6 as the configuration
I get an ipv6 but unfortunately I can't ping it via windows powershell
I tried almost all possible configurations but unfortunately it didn't work.
has anyone had the same problem?
thanks for the feedback
this my code :
/* BSD Socket API Example
This example code is in the Public Domain (or CC0 licensed, at your option.)
Unless required by applicable law or agreed to in writing, this
software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
CONDITIONS OF ANY KIND, either express or implied.
#include <string.h>
#include <sys/param.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_netif.h"
#include "protocol_examples_common.h"
#include "lwip/err.h"
#include "lwip/sockets.h"
#include "lwip/sys.h"
#include <lwip/netdb.h>
#define PORT CONFIG_EXAMPLE_PORT
#define KEEPALIVE_IDLE CONFIG_EXAMPLE_KEEPALIVE_IDLE
#define KEEPALIVE_INTERVAL CONFIG_EXAMPLE_KEEPALIVE_INTERVAL
#define KEEPALIVE_COUNT CONFIG_EXAMPLE_KEEPALIVE_COUNT
static const char *TAG = "example";
static void do_retransmit(const int sock)
int len;
char rx_buffer[128];
do {
len = recv(sock, rx_buffer, sizeof(rx_buffer) - 1, 0);
if (len < 0) {
ESP_LOGE(TAG, "Error occurred during receiving: errno %d", errno);
} else if (len == 0) {
ESP_LOGW(TAG, "Connection closed");
} else {
rx_buffer[len] = 0; // Null-terminate whatever is received and treat it like a string
ESP_LOGI(TAG, "Received %d bytes: %s", len, rx_buffer);
// send() can return less bytes than supplied length.
// Walk-around for robust implementation.
int to_write = len;
while (to_write > 0) {
int written = send(sock, rx_buffer + (len - to_write), to_write, 0);
if (written < 0) {
ESP_LOGE(TAG, "Error occurred during sending: errno %d", errno);
// Failed to retransmit, giving up
return;
to_write -= written;
} while (len > 0);
static void tcp_server_task(void *pvParameters)
char addr_str[128];
int addr_family = (int)pvParameters;
int ip_protocol = 0;
int keepAlive = 1;
int keepIdle = KEEPALIVE_IDLE;
int keepInterval = KEEPALIVE_INTERVAL;
int keepCount = KEEPALIVE_COUNT;
struct sockaddr_storage dest_addr;
#ifdef CONFIG_EXAMPLE_IPV4
if (addr_family == AF_INET) {
struct sockaddr_in *dest_addr_ip4 = (struct sockaddr_in *)&dest_addr;
dest_addr_ip4->sin_addr.s_addr = htonl(INADDR_ANY);
dest_addr_ip4->sin_family = AF_INET;
dest_addr_ip4->sin_port = htons(PORT);
ip_protocol = IPPROTO_IP;
#endif
#ifdef CONFIG_EXAMPLE_IPV6
if (addr_family == AF_INET6) {
struct sockaddr_in6 *dest_addr_ip6 = (struct sockaddr_in6 *)&dest_addr;
bzero(&dest_addr_ip6->sin6_addr.un, sizeof(dest_addr_ip6->sin6_addr.un));
dest_addr_ip6->sin6_family = AF_INET6;
dest_addr_ip6->sin6_port = htons(PORT);
ip_protocol = IPPROTO_IPV6;
#endif
int listen_sock = socket(addr_family, SOCK_STREAM, ip_protocol);
if (listen_sock < 0) {
ESP_LOGE(TAG, "Unable to create socket: errno %d", errno);
vTaskDelete(NULL);
return;
int opt = 1;
setsockopt(listen_sock, SOL_SOCKET, SO_REUSEADDR, &opt, sizeof(opt));
#if defined(CONFIG_EXAMPLE_IPV4) && defined(CONFIG_EXAMPLE_IPV6)
// Note that by default IPV6 binds to both protocols, it is must be disabled
// if both protocols used at the same time (used in CI)
setsockopt(listen_sock, IPPROTO_IPV6, IPV6_V6ONLY, &opt, sizeof(opt));
#endif
ESP_LOGI(TAG, "Socket created");
int err = bind(listen_sock, (struct sockaddr *)&dest_addr, sizeof(dest_addr));
if (err != 0) {
ESP_LOGE(TAG, "Socket unable to bind: errno %d", errno);
ESP_LOGE(TAG, "IPPROTO: %d", addr_family);
goto CLEAN_UP;
ESP_LOGI(TAG, "Socket bound, port %d", PORT);
err = listen(listen_sock, 1);
if (err != 0) {
ESP_LOGE(TAG, "Error occurred during listen: errno %d", errno);
goto CLEAN_UP;
while (1) {
ESP_LOGI(TAG, "Socket listening");
struct sockaddr_storage source_addr; // Large enough for both IPv4 or IPv6
socklen_t addr_len = sizeof(source_addr);
int sock = accept(listen_sock, (struct sockaddr *)&source_addr, &addr_len);
if (sock < 0) {
ESP_LOGE(TAG, "Unable to accept connection: errno %d", errno);
break;
// Set tcp keepalive option
setsockopt(sock, SOL_SOCKET, SO_KEEPALIVE, &keepAlive, sizeof(int));
setsockopt(sock, IPPROTO_TCP, TCP_KEEPIDLE, &keepIdle, sizeof(int));
setsockopt(sock, IPPROTO_TCP, TCP_KEEPINTVL, &keepInterval, sizeof(int));
setsockopt(sock, IPPROTO_TCP, TCP_KEEPCNT, &keepCount, sizeof(int));
// Convert ip address to string
if (source_addr.ss_family == PF_INET) {
inet_ntoa_r(((struct sockaddr_in *)&source_addr)->sin_addr, addr_str, sizeof(addr_str) - 1);
#endif
if (source_addr.ss_family == PF_INET6) {
inet6_ntoa_r(((struct sockaddr_in6 *)&source_addr)->sin6_addr, addr_str, sizeof(addr_str) - 1);
#endif
ESP_LOGI(TAG, "Socket accepted ip address: %s", addr_str);
do_retransmit(sock);
shutdown(sock, 0);
close(sock);
CLEAN_UP:
close(listen_sock);
vTaskDelete(NULL);
void app_main(void)
ESP_ERROR_CHECK(nvs_flash_init());
ESP_ERROR_CHECK(esp_netif_init());
ESP_ERROR_CHECK(esp_event_loop_create_default());
/* This helper function configures Wi-Fi or Ethernet, as selected in menuconfig.
* Read "Establishing Wi-Fi or Ethernet Connection" section in
* examples/protocols/README.md for more information about this function.
ESP_ERROR_CHECK(example_connect());
xTaskCreate(tcp_server_task, "tcp_server", 4096, (void*)AF_INET, 5, NULL);
#endif
xTaskCreate(tcp_server_task, "tcp_server", 4096, (void*)AF_INET6, 5, NULL);
#endif
and this what i get on the terminal:
PS C:\Users\jabno\test_tcp> & set IDF_PATH='C:/esp1/esp-idf/'
PS C:\Users\jabno\test_tcp> & 'c:\esp1\esp-tools\python_env\idf5.1_py3.11_env\Scripts\python.exe' 'C:\esp1\esp-idf\tools\idf_monitor.py' -p COM4 -b 115200 --toolchain-prefix xtensa-esp32s3-elf- --target esp32s3 'c:\Users\jabno\test_tcp\build\test_tcp.elf'
--- WARNING: GDB cannot open serial ports accessed as COMx
--- Using \\.\COM4 instead...
--- esp-idf-monitor 1.4.0 on \\.\COM4 115200 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode
IO, clock div:1
load:0x3fce3818,len:0x1758
load:0x403c9700,len:0x4
load:0x403c9704,len:0xc00
load:0x403cc700,len:0x2e04
entry 0x403c9908
I (27) boot: ESP-IDF v5.1.3-dirty 2nd stage bootloader
I (27) boot: compile time Aug 11 2024 18:18:47
I (27) boot: Multicore bootloader
I (30) boot: chip revision: v0.1
I (34) boot.esp32s3: Boot SPI Speed : 80MHz
I (39) boot.esp32s3: SPI Mode : DIO
I (44) boot.esp32s3: SPI Flash Size : 8MB
I (48) boot: Enabling RNG early entropy source...
I (54) boot: Partition Table:
I (57) boot: ## Label Usage Type ST Offset Length
I (65) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (72) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (80) boot: 2 factory factory app 00 00 00010000 00100000
I (87) boot: End of partition table
I (91) esp_image: segment 0: paddr=00010020 vaddr=3c040020 size=142a0h ( 82592) map
I (115) esp_image: segment 1: paddr=000242c8 vaddr=3fc93f00 size=02a18h ( 10776) load
I (117) esp_image: segment 2: paddr=00026ce8 vaddr=40374000 size=09330h ( 37680) load
I (129) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=3bd30h (245040) map
I (173) esp_image: segment 4: paddr=0006bd58 vaddr=4037d330 size=06b58h ( 27480) load
I (186) boot: Loaded app from partition at offset 0x10000
I (186) boot: Disabling RNG early entropy source...
I (198) cpu_start: Multicore app
I (198) cpu_start: Pro cpu up.
I (198) cpu_start: Starting app cpu, entry point is 0x403754d0
0x403754d0: call_start_cpu1 at C:/esp1/esp-idf/components/esp_system/port/cpu_start.c:159
I (0) cpu_start: App cpu up.
I (216) cpu_start: Pro cpu start user code
I (216) cpu_start: cpu freq: 160000000 Hz
I (216) cpu_start: Application information:
I (219) cpu_start: Project name: test_tcp
I (224) cpu_start: App version: 1
I (229) cpu_start: Compile time: Aug 11 2024 18:37:40
I (235) cpu_start: ELF file SHA256: 6ef825b125cb746e...
I (241) cpu_start: ESP-IDF: v5.1.3-dirty
I (246) cpu_start: Min chip rev: v0.0
I (251) cpu_start: Max chip rev: v0.99
I (256) cpu_start: Chip rev: v0.1
I (260) heap_init: Initializing. RAM available for dynamic allocation:
I (268) heap_init: At 3FC97BD8 len 00051B38 (326 KiB): DRAM
I (274) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DRAM
I (280) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (287) heap_init: At 600FE010 len 00001FD8 (7 KiB): RTCRAM
I (294) spi_flash: detected chip: generic
I (298) spi_flash: flash io: dio
I (302) sleep: Configure to isolate all GPIO pins in sleep state
I (308) sleep: Enable automatic switching of GPIO sleep configuration
I (316) app_start: Starting scheduler on CPU0
I (320) app_start: Starting scheduler on CPU1
I (320) main_task: Started on CPU0
I (330) main_task: Calling app_main()
I (370) esp_eth.netif.netif_glue: 02:00:00:12:34:56
I (370) esp_eth.netif.netif_glue: ethernet attached to netif
I (380) ethernet_connect: Waiting for IP(s).
I (2380) ethernet_connect: Ethernet Link Up
I (4360) ethernet_connect: Got IPv6 event: Interface "example_netif_eth" address: fe80:0000:0000:0000:0000:00ff:fe12:3456, type: ESP_IP6_ADDR_IS_LINK_LOCAL
this my code :
#include <string.h>
int len;
do {
if (len < 0) {
} else {
int to_write = len;
if (written < 0) {
return;
} while (len > 0);
char addr_str[128];
int keepAlive = 1;
#endif
#endif
vTaskDelete(NULL);
return;
int opt = 1;
#endif
if (err != 0) {
goto CLEAN_UP;
if (err != 0) {
goto CLEAN_UP;
while (1) {
if (sock < 0) {
break;
#endif
#endif
shutdown(sock, 0);
close(sock);
CLEAN_UP:
close(listen_sock);
vTaskDelete(NULL);
void app_main(void)
#endif
#endif
Build:Mar 27 2021
SPIWP:0xee
mode
entry 0x403c9908
