Hey folks,
Trying to understand the exact power requirements necessary for the LEDs circuits I'm putting together. My LED's are 3-4 Watts/foot and I am wanting to use one of the boards in the link below. It looks like the boards claim to have n-Channel 8W 12V FET Drivers. It looks like you then plug in N number of LED lights to the various channels and control them together or individual...I'm trying to determine if the max for the entire output is 8W or if it's 8W/channel or what?
Ultimately, I am putting in under cabinet lighting and need about 12 feet (~45W) of power (probably less but this is a good start). I want to control all the LED strips in the same fashion, so coding-wise I could just use one channel with all the LEDs wired together in serial...question is though...does that blow out the power?
If that is too much power, any recommendations on how to step up to the necessary power supply?
Thanks in advance!
https://www.controleverything.com/products?f[0]=field_assigned_categories:11678
Thanks in advance!
