Inverter rise time
GreenIce
Joined Jun 5, 2016
10
I said, for example 10f,but I want to know the physics why are not equal the rise times...I think this effect connected with the change of input capacitance pmos transistor...I take 32nm transistors from SAED library
dl324
Joined Mar 30, 2015
18,357
It's more related to the relative drive strengths of the PMOS and NMOS transistor. In older process technologies, NMOS drive was 1.5-2X that of PMOS, so PMOS devices were made larger to compensate for that. In later process generations, drive strength became more equal. I can't recall when the transition took place, but it depends on the process technology; and each company has different recipes.
You should be able to look up drive strengths in the process file.
