I will try making a high wattage inverter. I am thinking of using a thyristor bridge or mos transistor bridge.
By calculations, the thyristors should be able to handle 12W of power dissipation. The transistors 20W. Is that possible?
I am thinking of passing 20 ampers through the thyristors or transistors. The power supply will be a 12V panel.
