Invert output with switch
Tom544
Joined Mar 14, 2016
29
I have an 8 switch demo board using 8 pushbuttons to (2) sn7414 Hex Schmitt trigger inverters that works great. I would like to add something to this board to change the output from H to L with the flip of a switch. Would like to use the same output pins. Any suggestions would be great!
dl324
Joined Mar 30, 2015
18,436
If I understand correctly, you can put XOR gates on the inverter outputs and tie the other inputs together to a switch.
I used CMOS parts, so ignore the part numbers and pinouts.
Tom544
Joined Mar 14, 2016
29
Why do you need the Schmitt triggers?
If not, you just need the XOR gates.
Schmitt triggers and Caps cleanup the input from the pushbuttons!
Thanks for the suggestions! I will give the XOR gates a try. I have a 7486 that I believe will work.
Tom544
Joined Mar 14, 2016
29
Is there a way to use the XOR tied to a simple 2 pin switch to select Norm or Inverted? I don't have a 3 pin switch. Maybe with a pullup resistor? Thanks!
dl324
Joined Mar 30, 2015
18,436
Yes. As you suggested, put a pullup or pulldown resistor on the control inputs and use the SPST switch to change output to the other polarity.
