Internal Circuit Help
overlock_
Joined Aug 7, 2021
Hey Guys
Im trying to find each of the circuit blocks in the internal circuit of the LM6361 Op Amp
Im not sure if this is correct.
Ian0
Joined Aug 7, 2020
13,306
The rectangular box that you have labelled as "diff-pair" should include the upper diode (just under the box labelled 7). If you draw the diode as a transistor with its base connected to its collector, it should make more sense. Think of it as a current mirror with one input and two outputs, the input takes a constant current, so the outputs will both be constant currents.
The trapezium-box labelled "diff-pair" isn't - it's just two transistors. Note which terminal is connected to a fixed voltage.
"Differential pair" and the red and black boxes are correct.
You have missed a current mirror - the lower diode (above [4]) and the transistor below "differential-pair". It is important to note that the two current mirrors are both given the same reference current.
