My function generator is set to a squarewaveform at 1Khz at 5 volts
My intergator RC time is 100us
The voltage will RISE to 5 volts in the time of 100us?
Slope = time/voltage
100us/5volts = slope time of a intergator?
Linear intergation measurements is measuring the rise time and fall time
Exponential intergation measurements look like a shark's fen or it will tilt the "top" of the squarewaveform, the top either leading or lagging slanting
Symmetry
1.) the rise time and fall time ratio
Duty cycle is ON time / period X 100%
Symmetry formula is Rise time/ rise time + fall time X 100%
example of Symmetry :
1.) function generator set to a squarewaveform
2.) Intergator RC time is 100milliSec.
3.) Output would be a triangle waveform
4.) Symmetry rise time is 20mS and fall time is 80mS = 100mS
I haven't found a intergator circuit that has a variable rise time and fall time symmetry adjustment parameter, but its the RATIO of the rise time and fall time
A intergator that has a seperate rise time value and a seperate fall time value
I think the correct formula is this one , but i'm not to sure
Another Main point about intergators is the Charge and Discharge time
Rise time and fall time are "linear"
Charge time and discharge time is Exponential
Exponential is not a slope it more like a curve for the rise and a scoop or skirt for the fall, i guess thats what you call them, do you guys know the names ?
The rise of a charge time looks ilke a sharks Fen and the Discharge time looks like a skirt or scoop
Rise time , fall time = linear slope
Charge time , discharge time= exponential curve
Curve = time/voltage
Symmetry
