interference and ne555 and relays
bend94
Joined Feb 15, 2016
46
Hi everyone,
i did a first circuit with Timer NE555 managing a relay1.
i did another circuit with another relay2.
all is working well except in this case :
when relay1 is on (Timer555 is running) and relay2 is on. If i put relay2 off , the NE555 seems to reset the timer as a result the relay1 become off.
Someone can help ?
Regards
AlbertHall
Joined Jun 4, 2014
12,654
Do you have a catch diode across the relay coils?
Do you have a decoupling capacitor across the NE555 supply terminals very close to the IC?
Do you have a decoupling capacitor on the NE555 control voltage, pin 5?
bend94
Joined Feb 15, 2016
46
Well on the relay board there is a diode.
what is a decoupling capacitor .? have you got an scheme example ?
AlbertHall
Joined Jun 4, 2014
12,654
You should have a capacitor, say 100nF, from pin 5 to ground, and also between pins 8 and 1 (the chip supply voltage)
Also, the reset pin, 4, should not be left floating. If unused it should be connected to supply.
