interfacing the trimpot with ads1115 using Arduino mege
andhavarapu lokesh
Joined Aug 17, 2017
46
I tried to interface ads1115 using arduino and read the voltage of 10K poteniometer from serial monitor.
i got the error like this
Sketch uses 5782 bytes (2%) of program storage space. Maximum is 253952 bytes.
Global variables use 433 bytes (5%) of dynamic memory, leaving 7759 bytes for local variables. Maximum is 8192 bytes.
I made one more mistake i conncted 5V from arduino to Ads1115 VDD . Will the ADS1115 work or not
philba
Joined Aug 17, 2017
960
Errors are usually in red.
The ads1115 can handle 5V (max is 5.5V) so you probably did no harm as long as you connected +5V to the VDD pin.
Just upload the program and give it a shot.
