Interfacing Op-amp to DAC
Cosmin Traicu
Joined Jan 6, 2017
12
Hello, i was trying to interface a DAC (LTC8043) with a op-amp (MCP6021) using the schema from attach. The problem is that Vout is always 0 volts. But if i use only the DAC (Op-amp disconnected), the voltage at Rf pin (= Vout) isn't 0.
OBW0549
Joined Mar 2, 2015
3,566
That circuit produces an output of opposite polarity from Vref. With +2 volts on Vref, Vout would range from 0V to -2V, but since the op amp doesn't have a negative supply, it can't produce a negative output; so it just sits there doing nothing.
If you want a negative output voltage from this circuit, the op amp needs both + and - supplies, not + and ground.
If you want a positive output voltage, Vref must be negative rather than positive.
Cosmin Traicu
Joined Jan 6, 2017
12
My whole circuit is powered at 5V and voltage Vref is supplied by a voltage regulator, meaning that I can not set a negative voltage at the Vref pin. Is there another solution?
OBW0549
Joined Mar 2, 2015
3,566
Then the design you showed will not work. Your best course of action, in my opinion, would be to use a voltage-output DAC such as an LTC1659.
38,504
Page 7 of this data sheet for an equivalent device shows how to use it in a voltage mode with the Vref used as the output and the reference voltage applied to Iout.
You then can use a non-inverting op amp circuit at the output as a buffer.
That will give you a positive output with only a positive voltage supply.
Cosmin Traicu
Joined Jan 6, 2017
12
Using this configuration would i get the same slew rate? Thanks you.
