Interfacing LCD without MCU
legolas11
Joined Feb 26, 2013
55
Hi, is it possible to interface a LCD with a circuit output (analog) without a MCU. i mean i dont want to program a MCU, rather want a circuitry for interfacing (if any). any suggessions would be apprecited
takao21203
Joined Apr 28, 2012
3,702
its possible but doesnt make much sense. you need decoding IC or ICs
There is ICL 7107 which has 7seg driver for 4 digits.
NO info about the LCD.
12,130
With a datasheet and/or user manual for the LCD, it can be done. But plan on lotsa ICs. Sensor int A/D converter, data word or words clocked into a latch, decoded into equivalent BDC digits, multiplexed into LCD with necessary command signals.
ScottWang
Joined Aug 23, 2012
7,501
You could just buy a complete DVM display using an LED display, they are really cheap and work straight out of the packet no additional wires required when measuring over about 3V, single additional supply voltage otherwise. eg. http://www.banggood.com/0_28-Inch-2_5V-30V-Mini-Digital-Voltmeter-p-974258.html
I was think and tried to introduce this kinds of led DVM, but since the TS want to measure less than 1V, so I give up for this, I got this one in hand and designed the circuit for measuring the voltage less than 3V, but not completed yet.
pwdixon
Joined Oct 11, 2012
488
I think you can measure below 1V on some units it's just a case of having a separate power supply for the display. I haven't bothered to search for one that does measure below 1V that's left up to the OP.
legolas11
Joined Feb 26, 2013
55
nerdegutta
Joined Dec 15, 2009
2,689
0.28 Inch 2.5V-30V Mini Digital Voltmeter Voltage Tester Meter
Feature:
Detection voltage: DC2.5V ~ 30V
Working current: <30mA
Display: 0.28 inch LED
Dimensions: 31 × 12.0 × 9mm (length x width x height)
Installation hole: 23 × 10 mm
Measurement rate: ≥200mS / times
Accuracy: 1% (+/- 1 word)
Detection voltage is from 2.5v - a bit too high for your less than 1v.
ScottWang
Joined Aug 23, 2012
7,501
Oh, that's great, I will tell my friend that maybe he can buy that kinds of the type next times, thank you.
