I'm trying to use LMX04832 with external VCO with Si569 being the VCO. Chose CML as I think it to be optimal in terms of speed and power consumption. So, there is the trick. The LMX04832 datasheet provides no explicit data on interfacing between its clock input and a CML output stage. It seems like Si569 will not tolerate any external DC path between its outputs (see attachment), so they recommend placing a termination resistor after DC blocking caps. LMX04832 "wants" the opposite: termination before the DC block (the other attachment), which is understandable because the clock input is DC biased internally.
So, how do I actually interface these devices?
At the moment, it seems like CML may work if I use the same configuration as suggested by TI datasheet for LVPECL but without the emitter resistors (since they are not required by a CML output stage). The trace length will not exceed approx. 10mm. I will also try to simulate this and post the results later on.
