What i really need is beam detection not really beam break but essentially the same thingI thought you just wanted a beam break detector, all on or all off. You found a sensor that will demodulate your signal and turn it into an on or off output, as you need. Why do you need to pulse the transmitted signal, with the pulses not really being data?
I found that one sensor that detects continuous signals but the 56khz version is not available
I need both 38khz and 56khz
the 56khz version is 9 weeks away in china.
