interconnection of a solar pv system to a double-ended substation
alexia
Joined Dec 13, 2019
hi Guys and gals, I'm stuck on a question, I need to show interconnection of a solar pv system in California to a double-ended substation (substation transformers step from MV down to 480Vac), with a utility meter on both incoming feeds. I need a schematic of how this will look like on SLD..I just need the interconnection to the substation and can do teh rest myself.
Thank you,
Alexis
ericgibbs
Joined Jan 29, 2010
21,650
hi alexia,
Welcome to AAC.
If this is a Homework or College assignment, we need to see your attempt at answering the question, we can then help you.
E
alexia
Joined Dec 13, 2019
no , its work related, and I'm a solar system designer and I'm not a power engineer, I know how to design a PV system but I'm stuck with its single line diagram and interconnection as I don't know how does a Double ended substation looks like on diagram...I have designed the system all the way up to the connection point and am stuck at point of connection...even a sketch on a napkin helps resolves my issue! please
