Input filter
Ashad_27
Joined Feb 5, 2023
18
Hi
My circuit is getting input supply of 7V and 7A from other board that is a dc-dc converter with 100KHz switching frequency. How can i design a basic filter for my board.
Ashad_27
Joined Feb 5, 2023
18
I need to filter the input supply of my board. My board is getting input supply of 7V and 7A from other board that is a dc-dc converter with 100KHz switching frequency and ripple voltage of the converter is 40mV max . How can i design a basic filter for my board.
I have a space constraint, I cannot use the bulky inductors.
Papabravo
Joined Feb 24, 2006
22,082
The most effective way of doing what you are asking is with a common mode and a differential mode choke and their associated capacitors. It will be most helpful to specify the maximum ripple you wish to have on the input. Would it be possible to tweak the components in the SMPS to get a more favorable ripple behavior? For examples, replace the output capacitor with a part having a lower ESR?
Ashad_27
Joined Feb 5, 2023
18
Ashad_27
Joined Feb 5, 2023
18
will u suggest me any example ?
schmitt trigger
Joined Jul 12, 2010
2,085
Someone suggested me to use
powerline ferrite bead of 100khz at high impedance, 100ohm approx
10A rating
100 ohm reactance at 100 Khz means about 16 microhenries. No ferrite “bead” on its own will give that inductance value.
You require a proper inductor, which can carry the load current, like this. 10 uH should suffice.
Ashad_27
Joined Feb 5, 2023
18
