I just started industrial controls class. So far it is very interesting. Except I am not the best at drawing this problem up but I think the attachment is pretty close to the question. thanks for any help or ideas. it would be greatly appreciated.
1. A certain process has two tanks. Tank A has temperature control loop with a steam jacket. Tank B has hot water inlet from the Tank A and cold water inlet from the top. The following assumptions can be made regarding this process :
1. The temperature of tank B is controlled only by the amount of hot water from tank A.
2. The level in tnak B is controlled only by its cold water inlet.
Draw a control diagram showing:
(a) control temperature at the outlet of tank B
(b) control level of tank A
(c) control level of tank B
I think I need to draw something like the attachment except with two tanks labeled A and B. i know I need to study it more but a little help in the right direction would be good also.
