Inductor Selection help for varying voltage.
DocQBN
Joined Jan 2, 2017
32
Hi there,
I'm trying to build a varying voltage supply (1.2-1.8) with the TPS548A20 by TI. I've been using their WEBENCH tool and have calculated for 1.2V I'll need a 1.5uH inductor and for 1.8V I'll need a 2.2uH inductor both @400kHz. I would like to keep Iout above 10amps. The voltage input will be either 12 or 5 volts. I looked at the datasheet to find the equation for the inductor and plugged that into a spreadsheet (attached). My question is when choosing the inductor, should I choose an inductor that meets my minimum Iout even though it has the ability to exceed my Iout rating on the IC? Should I be concerned with the frequency I choose? What's the best practice in this case?
38,769
You can as long as the peak inductor current will never exceed the inductor's current rating.
A higher frequency allows the use of a lower inductance inductor, but possibly with a lower conversion efficiency.
DocQBN
Joined Jan 2, 2017
32
Ok, thank you. I figured that would be the best option I just wanted to see if there was a preferred method or some industry standard I didn't know about.
