You are trying to determine an "impedance" where impedance has no real meaning or use. It's a nonsensical question, at least at the engineering level...........................
How do you determine the impedance if the wave is made up of an infinite number of harmonics? If you add the sum of each one then you get infinite impedance???
Waves do not have impedances.Ok,
So I have been studying Fourier analysis and transform videos on youtube.
I see that by adding a DC component the pulse may be made unipolar.
What I'm still not understanding is this.
No you don't. It depends entirely on the relative magnitude of the terms. In the Calculus you might study sequences and series. One of the things that you find is that many infinite series add up to a finite value. There is even an online encyclopedia of sequences and series along with their sums.Ok,
What rise time?Because the V/L is your rate of current change over time then 100A/50uS is 5mA. This is how long the charge is flowing for before you turn it off. The longer the on time the higher the current. As long as the rise time is much much smaller than the pulse width then the above holds true doesn't it.
Adam
You probably start where the rest of us started - in a learning environment where that material is taught in a systematic manner. If that doesn't suit or is impractical then it will be a hard slog teaching yourself. Whilst a stong mathematical foundation is a great benefit the real challenge is grasping the physical truths.Ok,
I must be asking a question that is beyond my knowledge.
So, where do I start to learn about Fourier and Laplace transforms and analysis? I have only been as far as high school algebra.
Where should I start?
Pretty much all learning involves asking (or being asked) questions that are beyond our knowledge. So don't let that bother you.Ok,
I think the original question was has the pulse width anything to do with the maximum current not what will happen to the current in time. The 50us pulse is what will give you the maximum current for that duration. Yes the current will carry on forever in an ideal inductor but it won't increase. If you increase the on time then you will increase the maximum current. I think that's what he means.What rise time?
Before you turn what off? The voltage? If you turn the voltage off (i.e., force it to 0V), what happens to the current? It keeps flowing!
I don't have time for math - I would rather toast something ...Pretty much all learning involves asking (or being asked) questions that are beyond our knowledge. So don't let that bother you.
But you ARE trying to bite off a whole lot in one fell swoop. Laplace transforms are typically taught at the very end of a course in Differential Equations, which in turn typically follows three semesters of Calculus, which follows Trigonometry, which follows Geometry, which follows High School Algebra.
If ALL you want to know are Laplace and Fourier transforms, then you could probably tighten things up somewhat, but you still have a significant hill to climb.
The fundamental concepts of Calculus are actually quite easy to grasp -- but if you don't have solid algebra, trig, and geometry (and ideally analytic geometry) skills as your foundation, the mechanics of any practical application will quickly overwhelm you.
I have done analog design for all my career and have seldom used Fourier analysis or Laplace transforms. Most of what you need to do for circuit design and analysis can be done using algebra along with basic calculus and an understanding of complex numbers. So where you start depends upon what you really want to do.Ok,
by Jake Hertz
by Robert Keim
by Jake Hertz
by Jake Hertz
