inductive motor wiring - label is very vague
oz93666
Joined Sep 7, 2010
742
Well that shouldn't be a problem , particularly if you haven't removed it yet ..
Remove the motor and the capacitor from the machine , leave the wires connecting the two intact , then there should be two wires spare , these connect to the mains .
Eli Konky
Joined Sep 19, 2018
6
That's what I did. But I have 3 wires:
MaxHeadRoom
Joined Jul 18, 2013
30,804
That appears to be a PSC motor where the coils are equal in order to supply L1 to the black and either L2 (or N) to ONE of the other Yellow-Brown conductors, this achieves reverse in a PSC motor.
Only in a dryer it normally does not need reverse?
Your measurements appear to confirm PSC of equal windings.
Max.
Eli Konky
Joined Sep 19, 2018
6
Max.
Thanks Max. Can you point me out to the correct wiring?
Eli Konky
Joined Sep 19, 2018
6
Thank you. Do you mean I don't need to hook up anything to ground? Just black to one main and either yellow or brown to the other main?
Eli Konky
Joined Sep 19, 2018
6
YES!
Thank you very much @Max. It worked.
@oz I tried out one of the windings and it worked. Haven't tried the other just yet but from what @Max said seems to me that you are correct.
This was the first motor I salvaged. Hope to put it to good use.
From what I've read, an induction should have some kind of a mechanism to start off the motor and another one to make the start winding stop working. I didn't see anything that might cause this start mechanism (if it indeed exists) to stop.
Eli
MaxHeadRoom
Joined Jul 18, 2013
30,804
The acronym PSC is Permanent Start Cap motor, so in this type of motor up to about 1/2hp the start cap and winding are permanently connected, i.e. no disconnection method once up to speed.
Typically achieved using a centrifugal switch.
Max.
