Induction heating
gustr
Joined Mar 8, 2017
Is it possible to use a spot welder attach it to copper ring to heat up mild steel tube 72mm in diameter need it to get around 240 degrees cel ?
if not use a microwave transformer pass direct current hook it up to the copper coils to act as induction heater
Any other very cheap alternatives are open the aim is to get a mild steel tube to 240 cel doesn't have to be through induction
MaxHeadRoom
Joined Jul 18, 2013
30,841
If the spot welder has the capacity, and you could find a way to place the M.S. between the electrodes fixed securely and apply power, the secondary can be anything from a few hundred amps to many thousand, dependent on the capacity.
The MOT will not act as an induction heater on its own.
Max.
GopherT
Joined Nov 23, 2012
8,009
Id use a propane torch with a flame spreader. Possibly two if you have a friend.
Reloadron
Joined Jan 15, 2015
7,954
240C 464 F. with a 74mm 2.84" Depending on the tube length if you could clamp each end and run a current through the tube it should heat up, I have no idea how much current would be required. We used this method to create super heated steam in stainless steel tubing. I don't see induction being used here.
Ron
tcmtech
Joined Nov 4, 2013
2,867
How long is the tube area that needs heating?
What's in it or passing through it?
How quickly do you need it to get to 240 C?
How accurate does it need to keep the temperature once at 240 C?
