how the induction heating works in distance or is it even possible?
tls123
Joined Jan 31, 2021
Hi, im kind of wondering if the induction heating at distance can be possible,
like the coil and the work piece kept at distance gap(~10cm),will it work?
35,268
The induced magnetic field decreases as the square of the distance.
Hence the field at 10cm will be a 100 times lower than the field at 1cm and 10,000 times lower than the field at 1mm.
Reloadron
Joined Jan 15, 2015
7,975
I doubt at 10 cm you will get much energy. As MrChips points out the field drops with the square of the distance. I have annealed brass at a distance of about 1 cm and that was with considerable current in my coil. Maybe 40 amps as I can't recall.
Ron
tls123
Joined Jan 31, 2021
Very helpful..thank you :)
The above principle ("the field drops with the square the distance") ,is it same for under vaccum condition?
BobTPH
Joined Jun 5, 2013
11,665
Actually, this is only true for a point source, of which there are none for magnetic fields, or at large distances. At distances comparable to the size of the source, the field is much more complicated.
Bob
