Induction heating machine button replacement
Alexeberk
Joined Jun 18, 2022
9
Hi everybody!
I need your help to find a replacement for a switch for my induction heating machine.
I'm a novice in electronics so I don't know where to find a replacement for the switch I need. Thank you very much  IMG_20220618_115754.jpgIMG_20220618_115841.jpgIMG-20220613-WA0000.jpegIMG_20220618_115345.jpgIMG_20220618_115827.jpg
28,299
OK this will be interesting because that is not a standard push button. We do not see the rest of it, but I am guessing that it was a membrane switch. That was an incredibly poor choice by the equipment builder.
The switching function will be "single pole, normally Open" = SPST-NO. The selection will depend on the space available behind the mounting position. As we have no information about what is in that area behind the button position I am unable to suggest any specific replacement.
So we need to know what that part of the product does and what is behind the spot where the button was mounted.
MaxHeadRoom
Joined Jul 18, 2013
30,810
Very often it is the conductive material on the PB itself, kits in this material are available for PB repair.
It should be easy to test the switch surface itself by placing a metallic foil 'patch' over the conductors.
Alexeberk
Joined Jun 18, 2022
9
Behind the mounting position there's nothing only the induction magnet but has a different wiring. If you need I take a picture of the central unit where the switch is cabled to the mother board..
Do you think there's someone who sell this kind of switch? I've tried also connecting directly the two wires without the switch but didn't start the machine...
Alexeberk
Joined Jun 18, 2022
9
If you do not already have a multimeter then buy one so you can test the switch to be certain of its function. If, as I suspect, it is a momentary contact switch that briefly closes as you press it to initiate a start function then something like this https://uk.rs-online.com/web/p/push-button-switches/8780836 would do the job. firstly though, you must make sure of the function of the existing switch.
I tested with the multimeter and is normally open and when I push has ~2000 ohm resistance. And work at 12 V. Do you think this as difference from a nornal switch?IMG_20220618_115754__01__01.jpg
MaxHeadRoom
Joined Jul 18, 2013
30,810
The 2k SMT resistor can be seen in the pic, did you use one on the remote switch?
From your reading, the resistor is in series with the switch when pushed ?
Alexeberk
Joined Jun 18, 2022
9
I didn't find a switch with this resistor yet. I think noww Is what I need. I think is in series when pushing the switch
MaxHeadRoom
Joined Jul 18, 2013
30,810
Any switch you find, you most likely will have to wire in a separate resistor, wire it in the lead.
This may make it possible to use any contact-closure PB. switch
28,299
Now the entire scope of the project is very much different! First it was to replace a failed switch, now it is to add a different momentary switch someplace else. THAT project is simple and does not require so very much good fortune. In addition, that 2000 ohm resistor is a whole new concern.
A momentary action pendant switch is often available from industrial equipment sellers. There is even exactly that that was sold for automotive mechanics to use for engaging the starter motor to turn engines. I own one of those! They are very simple indeed. That is, or at least was, a standard automotive mechanic tool. You would need to change the cable and add the resistor in series, that will not be difficult.
Alexeberk
Joined Jun 18, 2022
9
Thank you very much! I will try to do as you say! Do you have an example of that momentary action pendant switch?
28,299
No, the one I have may also be called an "engine jogging switch". I don't know if mechanics even use them any more. An on-line search with that keyword, ("engine jogging switch") may reveal something.
MaxHeadRoom
Joined Jul 18, 2013
30,810
I am not that much in favour of switches on the end of leads, is there no permanent spot you could mount it?
Why would you need a mobile switch on a induction heating M/C?
Alexeberk
Joined Jun 18, 2022
9
Yes i would mount it on a tubolar andler. Because to use it better I need to see from a little more distance where I'm working on dented surfaces.
28,299
The reason for the remote, Max, is that it is a dent removal tool for automotive repair work. Users often need to be able to see just what they are doing when getting rid of dents.
