Inductance proximity sensor output conversion to 3.3V logic
TeeKay6
Joined Apr 20, 2019
573
The MOC8101 is rated for an abs max LED current of 60mA. Using the circuit of comment#15. Assume the sensor is powered from 18.0VDC, that the PNP output transistor of the sensor drops 0.0V min (1.8V max), and that the forward voltage of the MOC8101 LED is <1.5V, then a current limiting resistor (R1) is required to keep the MOC8101 LED drive within its spec. LED current = (18-0.0-1.5)/R1 = (16.5V)/R1 = 0.06A. Thus, R1 must be greater than 275 ohms. For your use, R1 = 1000 ohms would be appropriate, giving an MOC8101 LED current of about 16.5mA and a current of 8.3mA minimum through the photo transistor (50% CTR from datasheet).
