Hey guys! Does anybody know how i can increase the voltage without changing the current?..Thanks in advance..
Actually; what i'm trying to do is increasing the voltage of my output current which came from my current limiting circuit .. In some way i used , i could limit the current to the specific value but while doing this i also limited voltage ..I want my dc motor to take the voltage it requires but not giving the current over a specific value like 200-300 mA..so, i thought maybe i can increase the voltage later i limited the current..It might be very stupid idea indeed but what can i say i'm just a beginnerWhat you have described is a constant current source?
What is the magnitude of the constant current that you need to generate?
hgmjr
No, I'm not that guy but that seems interesting though To do something like that tunnel diodes might be handy, i guess..Are you the guy with a little fan in your helmet powered from a little 9V battery and you want to double the voltage, quadruple the power but not increase the battery's current?
