Increasing the current without changing the voltage
Leo448
Joined Feb 9, 2012
Searching for a Sch. to build a Power Supply with Hi Current / 25 to 30 Amps....
I would like to be able to Adjust the Voltage & Amp. independently from each other.
It would help to know how I could Boost the Current Theory, on a Power Supply....
Veracohr
Joined Jan 3, 2011
783
If you have a voltage source the output current is determined by the circuit. If you have a current source the output voltage is determined by the circuit. You can set a limit for current or voltage (respectively) but you can't set the output value of both for a given circuit.
