Increasing the output current to a resistor network using transistors
Ian0
Joined Aug 7, 2020
13,278
So when I know the gain, what is the next step?
Thanks a lot for your comments and sorry if I m asking novice questions
Next, work out the base current. Then ask yourself if the previous stage can provide enough current.
If the answer is "no" then you need to add additional devices to give more gain, like @crutschow said in post #13
Nabil Miri
Joined Jul 20, 2022
44
Ok so lets imagine that for a 100 mA base current we get a gain of 25, meaning that the output is 250mA. What other voltage params should I take into consideration. For example. should the Vce be saturated etc...
Nabil Miri
Joined Jul 20, 2022
44
Not normally.
And as stated, you want to use the minimum gain value, not the nominal that curves often show.
in this table it is written Vce = 2V. So is this the minimum Vce or what happen if the Vce is different, how does the gain changes?
ci139
Joined Jul 11, 2016
2,033
What you want to do is quite simply impossible. Changing the bias on the transistors changes the effective resistance which will lower the current, but there is nothing you can do with that circuit to increase the current.
That does not sound entirely correct . . .
If we remove the redundant (error source) "Voltage Follower" we got the Gain 3x amplifier . . . which due the particular BJT power gain stage has zero crossover distortion . . .
if we replace the bjt stage with highly sophisticated dc2dc module that has a capability to ramp sufficiently fast in response to the (what it seems to be) square wave stimulus - then what the OP asks is doable . . . if he can find sponsors to this project
the alternative is simply to provide a higher supply and use the "Voltage follower" as down-scaling stage to add current
Papabravo
Joined Feb 24, 2006
22,111
That is essentially what @Alec_t said in Post #2, and I do not disagree with what you propose.
38,813
An increase in Vce will cause a slight increase in Ic due to the output conductance of the transistor (hoe).
This will look like a small increase in the gain.
Normally the change is small enough that it can be ignored, compared to the normal variation in current gain from other factors.
ci139
Joined Jul 11, 2016
2,033
besides that - i did get your point . . . only wanted to emphasize/remind that outside the "box" it's possible
it pretty much look like an inside the bubble case when you (OP) default(s) to a certain method and are temporarily unable to see other methods avail.
a kind of an overworking stress . . . and a quite typical situation i've and often found myself at
Nabil Miri
Joined Jul 20, 2022
44
I have the below circuit and when I add the current follower op-amp circuit to my circuit it doesn't work. If I added an ideal op amp it works but when changing it to a realistic op amp it doesn't. What would be the problem?
Realistic:
Ideal:
Nabil Miri
Joined Jul 20, 2022
44
166V output from VE4?
Ohh yes I didnt notice that. The real op amp output wont reach this voltage levels.
This circuit current reachs up to 800mA. But I don't think that is it a good idea to put an op amp with an output current of 800mA or supply high voltage.
So is there any other possible solution to solve this problem?
Ian0
Joined Aug 7, 2020
13,278
Not quite sure what VE4 is actually meant to do.
It will try to maintain the non-inverting input at 0V, so why not simply connect the bottom of Rw to 0V ?
Nabil Miri
Joined Jul 20, 2022
44
The VE4 is a -22V source.
If I connect the Rw to GND, no current will flow to the current follower circuit. I am trying to find a way to convert the current flowing in the circuit to voltage for measurement reasons.
Ian0
Joined Aug 7, 2020
13,278
Use a small value of shunt resistor, say 1Ω or 0.1Ω, and measure the voltage across it. That would work with a multimeter with a decent mV range. If you are measuring it with a A/D amplify the voltage with a INA180 or similar.
