increasing the delay time on a remote?
Max104
Joined Apr 18, 2025
I am trying to increase the delay time of this product to 10-15 seconds. Could someone get me in the right direction? https://a.co/d/ddqARBv. or is there a product already made to meet my needs? 2 channel rf remote transmitter with 10 second delay?
AnalogKid
Joined Aug 1, 2013
12,266
Please describe in detail what it is you are trying to achieve? What does the relay control? When/Why are they activated?
Do you want the receiver to activate the relay 10 seconds after it receives a valid signal from the remote? If so, what happens if the button on the remote is held down longer than 10 seconds? Does the relay activate at 10 seconds, or wait until the button is released?
What happens if the button is released and pressed again during the 10-second delay? Does the delay timer restart at 10 seconds, or ignore the extra button press(es), or something else?
No matter what your answers are, it probably is not possible to modify the board to do what you want. There are no adjustments, and there is an 8-pin device that smells like a microprocessor. I'd be surprised if the delay time is set by a simple R-C network, but you might get lucky. If that doesn't work out, the question becomes what other module to add to the system to get the delay action you want, but we need more information to get there.
ak
Futurist
Joined Apr 8, 2025
947
I see it has a "5 second" delay mode and assume you'd like to make that longer?
Take some hi res close up pics of the various chips and stuff, unless we know more it would be a guessing game.
If that 8 pin device is an NE555 then there's a possibility...
Have you tried emailing the manufacturer?
Blue PCB.
