With some of the frequencies mentioned; I'm wondering whether that's the root of the problem.I believe that the most basic circuit will deliver a current similar to what you want. As an example, see Figure 10 in the data sheet I posted earlier.
Agreed.With some of the frequencies mentioned; I'm wondering whether that's the root of the problem.
Did you see the size of his inductor? How big is yours and what is the value of its inductance?I took a look at this post.
https://forum.allaboutcircuits.com/...ncy-smps-buck-converter-using-34063-ic.78805/
The timing capacitor is 1 nanofarad, which resulted in a 26.2 khz output. Will that be good for the transistor?
