increasing boost converter efficiency
pager48
Joined Nov 25, 2018
161
aside from choosing a low resistance inductor wouldn't ganging diodes increase dc regulator efficiency simply because the I-V curves are exponential?
ArakelTheDragon
Joined Nov 18, 2016
1,366
does a regulator with built in mosfets have greater efficiency over bjt regulators?
thank you.
Adding more components normally does not increase efficiency.
Can you give a circuit?
The internal MOSFets should be with smaller and low resistance traces. They can even be with a low resistance drain source channel, but thats device specific, not an efficiency factor.
