Increasing Arduino Voltage
lhern034
Joined Oct 23, 2017
46
I was wondering if anyone knew how to increase the output voltage of an arduino from around 5 V to a range of around 10 to 20V.
It does not matter if I need another power supply. I'm outputing in voltage pulses and I'm using it to activate a
MOSFET from the gate
Digi-Key Part Number IRF530PBF-ND
DickCappels
Joined Aug 21, 2008
10,187
This is the basic inverting circuit, but VCC would be the higher voltage (10V to 15V). If you want to switch the MOSFET quickly you will need a little more complicated circuit.
