increase hysteresis for gate driven by hall? (with schematic)
Hamlet
Joined Jun 10, 2015
560
I need to increase the speed by which it turns off (turn on is a little too slow too)
All I have are my eyeballs to evaluate the speed, and it seems slower turning on, than off, persistence of vision not withstanding.
I want to pair up this circuit, using two hall sensors, back to back, so that when a magnet turns one off, the other is turned on, and finally,
mate the signals to an H-bridge. (I'm trying to prevent shoot-thru.) Maybe it don't matter, cause hall sensors switch fast, so shoot-thru might
only last a milisecond?? What do the brains think?
For turn-off, you need a gate resistor to ground.
For the ultimate in speed, you need a gate driver to overcome the gate capacitance. The voltage across a capacitor can't change instantaneously hence, some slowness. Your not actively or passivly draining away gate charge when you turn it off either.
K General Electronics Chat 6
