I have a loadcell being amplified by an INA122P but at the initial weight being applied to the loadcell the amp is not outputting any voltage.
What is the best way to increase this so it registers just the slightest force ? Should I change the resistor or capacitor value and if so up or down ?
This is the circuit I am using :
I have a 500ohm pot to change the sensitivity but if I put it down as low as possible (highest sensitivity) then it still doesn't register slight pressure and then it goes to full ouput with just a little more pressure. It is a 50kg loadcell and I need it to register full output at 50kg force but still register with just 1kg or less force. Is this even possible ?
The capacitor I have is marked .2A224J
