INA122 simulate fail on proteus
Huyyuh
Joined Dec 27, 2021
Hello, I'm having loadcell simulation assignment and I design like pic. Because proteus doesn't have loadcell that I want so I model it as a voltage source. My problem is INA122 doesn't amplifies signal like theory. According to datasheet, Vo = Av*((V+)-(V-)) as Av = 5+200K/Rg so when I adjust Rg = 10K, the voltage should be amplified 25 time and voltage out is 2.5mV*25 = 62.5mV. But it always 337mV like the pic. I don't know how to fix, please help me. Thanks in advance
ericgibbs
Joined Jan 29, 2010
21,439
hi Huy,
The 2.5mV test signal should not be referenced to 0V, especially when using a single supply IA.
Add two 1K 0.01%, resistors in series from +V to 0V, place the 2.5mV source in series with the resistors, the 2.5mV source now is offset by +V/2.
E
NOTE: You must have a Vref voltage in order to lift the INA Vout above the non-linear region, 2nd image, when using a single supply
