In which cases we use "Twisted Pair" cables
pars842
Joined Jun 20, 2017
3
Hi everyone,
I blindly use twisted pair cables for power lines. I twist Power and Return cables. Also, I always twist differential signal cables. For example; Tx+ and Tx- in RS422..
I don't know the benefits. Can someone clarify when do we need to use twisted cables.
Picbuster
Joined Dec 2, 2013
1,059
Take a transformer changes in one coil will be inducted in the other one but phase shifted (180 degree)
twisted wires behave the same.
pulses are a change and inducted in the other wire but with Pi radians shifted hence they eliminated.
that's why we use twisted pairs but the impedance is effected hence maximum transmission frequency limited by cable quality.
Picbuster
30,692
In the case of high power cables there is a cancellation effect of radiated energy (EMI/RFI) when the conductors are twisted together.
38,543
It can have these effects:
Cancel radiated energy from the wires.
Cancel noise pickup in the wires from EMI sources.
Provide a constant cable characteristic impedance.
